Nd5 xs2 is connected to nait 5si. From a Marantz SA8400 SACD reader a coaxial cable enters input 3 of ND5 xs2. All this because the Nait5si has all the inputs occupied.
That was the question, whats connected to the amplifier ???
The Nait5si is connected, an ND5 xs2, a TT15s1 Marantz turn table with Rega Aria , a NA7004 Marantz, 1 cable for SR7400 Marantz sourraund amplifier in automatic AV.
OK, all the Marantz & Rega connected devices are not earthed (grounded) & have only L & N two pin IEC320 connections. In theory, because none of the devices are earthed, the ND5 switch should be set to Default
I do not understand. Should I move? However I do not hear any hissing like that!
Its common that there is no difference in sound. In your systems case with no other equipment with an earth/ground, the ND5 switch should be set to Default, this will connect the Naim signal ground (-ve) to earth.
