I have a new NAP 250 DR with a 272. I am trying to connect my SVS 13 Ultra Sub to the system but can’t figure out how to do it. Do I have to connect via the speakers? If so, the speakers use banana plugs and the sub uses rca connectors. What adaptor do I need?
From what i can see of the SVS 13 Ultra subwoofer, connection is only via low level, so you would need to take a pre-out signal from the NAC-N272 to the subwoofer. You’ll need a suitable 2 x RCA Phono sub lead for this - make sure it’s of low capacitance.
I tried that first, but no signal. The sub worked fine with my previous SuperUniti using the sub output, but not with the 272. Is the SuperUniti hi low output connection?
