Hi!
I am trying to connect my TV (Sony Oled 55 inch) to my first generation Unity via an optical digital connection. However, I cannot select the digital input on the Unity. When I toggle through inputs it doesn’t come up as an alernative.
I do not have the instruction book and it seems no longer to be available on the Naim home page.
Can anyone provide a suggestion?
Sounds like you need to enable the input from the menu, press the spanner button on the remote & navigate to “Inputs” select the digital input you wish to use & select “Enable”. You can also rename the input if you wish.
