Hi,
I am wondering how can I do to rip cd’s from the Uniti Atom. I plugged USB CD player on the front and on the back of the Atom, I hear that it’s powered but I can’t see it in the App. Can someone explain me how this work ?
Best regards,
Hi,
Best regards,
A precision : when I go to “USB”, I don’t see the USB CD player, only the HD.
Best regards
The Atom does not have ripping capability unfortunately. The only new Uniti player which does is the Uniti Star (and the Core as a dedicated ripper/server).
The most common routes are either a dedicated ripper such as the Core or alternatives from others such as Melco, or using a computer to rip, the most common app is probably dbPoweramp on a PC.
