Help identifying a bike
To my fellow bikers.
Looking for some help trying to establish details of an old motorbike.
See photo I found of my father in his youth riding what’s clearly a matchless.
I would love to find out more details of the exact model, if possible from the image.
I was thinking of trying to find one to buy and show to him, to recall some of his happy day memories.
Thanks in advance
It looks like a Matchless. Either a 350 or 500 single. Dont know the model though.
The photo dates back about 68 years ( I think) so circa 1955 or thereabouts
Google search found that
I think it might be a circa 1954 Matchless 348cc G3LS
Im sure you have already but possibly try one of the Matchless motorbike forums or similar?
Good idea Neil, will look in that direction.
Tnx
Paul
Thanks for that
Will research a bit more along those lines
Pretty sure its a 350gls. Same engine as the ajs 350 I had briefly as my first post learner bike. Being 1971 it was chopped obviously :sunglasses:
Maybe Java motorbike ? I searched with google image search
IMG_2344
As we say maybe you need to go to specsavers :wink:
The reason I say 350 is that the 500 had a shaped ( bendy) side case.
54-56 I think as the later ones had a bottom crank case and no upwards side case.
The tank badge is Matchless.
The visible external valve actuation suggests (to me at least) a 350 rather than a 500.
Don’t know what you mean by specsavers. I know nothing about motorcycles. Wanted just to see if the google research images gave something. Apparently not. Anyway it took me 20 seconds.
Its a high street chain of Opticians, in the UK… :expressionless:
It means you need to get a new pair of glasses…
In the UK TV advertising they show professionals making absurd misjudgements (like a vet trying to find the pulse and give life saving care to a fur hat as the cat he was supposed to be treating is off to one side).
The voiceover says “Should have gone to Specsavers”.
LOL. It is a Matchless, it says so on the tank. It is the old possibly pre war design, not the late 50’s one. It is likely the 350 engine the same as I had in my AJS (same company). It is a slow old long throw thumper but looked cool as, with its side case and tall cylinder in a semi chopped 70’s ‘omage to Easy Rider. :grinning:
Good joke :+1:. I agree, I need better glasses :grinning::disguised_face:
I’m not so sure it’s a 350. It could be a 500 which would make it a G80, maybe? As to the year, that looks like a Burman gearbox which would date it to pre 1956 and the photo makes it hard to see the suspension. Is there a jampot type shock there or is it rigid? The toolbox just visible behind your Dad’s leg looks to be '55 or earlier.
G80 54/55
matchless-g3ls-1955-1
G3ls '55
F12z-fc
G3ls '53
So hard to tell but op pic looks straight.
Edit, my bad, pic shows my AJS model.
Below Matchless model
IMG_1185
