The strangest thing has happened to my NDX 2. I was streaming Radio Paradise when I had to mute. When I tried to unmute, it just refused to do so.
The NDX 2 is connected to my Supernait 3 through System Automation (with a 3.5 mm cable) and has been working fine until now.
I have tried restarting the both the NDX 2 and Supernait 3 (thrice) without success.
The Supernait 3 seems to be fine. When I select the turntable input it plays music.
The mute light on my Supernait 3 is off (unmuted) but I simply cannot stream anything through the NDX 2. I have tried to stream internet radio, Tidal and my music collection from Uniti Core- nothing works. The NDX 2 screen shows the music selected (the album cover from the Core for example) but no music is being played.
All cables and connections are in order.
Has anybody experienced this? It seems the NDX 2 is stuck in mute? Can somebody please help?
I am sorry @PeterR, I may be missing something from your reply. Do you mean such things are supposed to happen? I am ok with it happening, I get that it’s a streamer; but I would just like it to play music again.
I was asking because on the Beta thread an issue came up where the app and remote mute buttons go out of sync and you have to do some gymnastics to unmute, but on re-reading it is not what you were seeing. (This is already being fixed by Naim).
It is possible that this only happened in the Beta version and not in the release firmware that you have:
“If I mute the volume with the mute button on the remote, changing the volume through the app (volume up button or slider) does not work. The only thing that works (other than grabbing the remote) is unmuting the volume in the app (by tapping the volume icon), then muting it in the app, then unmuting it again in the app (yes, three taps).”
