Help needed
Hello everyone
I have 2 ,2011 uniti’s my Naim stageline connected to the phono input one of them works fine,I connected to my other one and it doesn’t power up ,looks like it has lost the 24 volt output /made the phono active on the remote and nothing
The stageline has the original snaic cable,
Any ideas
Many thanks
If the Stageline and SNAIC are the same in both cases then it would indicate a problem with the powered AUX2 socket on one of the Unitis. Time to arrange with your dealer for it to be serviced at Naim.
