Pleased you have found a solution albeit one that means lots of labourious file copying.
Ok so what is going on here is that Naim locks the Music folder on the SD card in a Star in the same way it does in any Naim server, which is fair enough as edits could break the indexing of the Music Store. The downloads folder being open is also consistent with UnitiCore and Unitiserve etc.
It seems rather random and unnecessary that Naim prevent the SD card being read in another Naim Uniti product. But no doubt the developer responsible for that decision would say it’s a feature and not a bug.
But it shouldn’t involve a lot of tedious copying to sort it out. All the files in the Music store can be copied in a PC and then saved onto a new SD card in one go (or two gos if there are files in the downloads folder). They don’t need to be done separately at all.
Best
