I believe it’s different between UK and rest of Europe then because my Naim cables are 1mm2 and same with my Music line netzleiste which use a Naim cable.
Hello,
I would use the one with 1.0mm cable for the NAP200DR.
Although it does seem a little on the skinny side and would consider 1.5mm or better to be desirable.
@ RichardPW The EU shuko lead maybe thicker to cater for circuit breaker tripping, as shuko plugs are not fused.
