Hi everyone, I’m freaking out! my supernait 3 still under warranty crackles on the left channel when i turn up the volume, the support said the problem is in the electrical system in my house.
I mounted a dc blocker but nothing happens, what could it be?
does it happen when you use the remote, adjust the volume manually or both? My SN3 can make a noise when I adjust volume with the remote, which I assume is noise from the voume pot motor. Doesn’t seem to have any impact otherwise.
Might be the volume pot is a bit dusty.
Switch off and turn it up and down a few times then turn it right down and switch on again to check.
I see no reason whatsoever that someone would say it’s your house electrics affecting one speaker.
Both the dealer and the after-sales service have the same opinion: the problem is the house wiring.
I’m really tempted to sell everything and get a class d amp and make my life easier!
Can I just check. Do you mean that there is a crackle on one channel just while you are actually changing the volume? Or do you mean that when the volume is high, you hear a crackle all the time?
Try completely turning off the ethernet over mains and disconnecting them from the mains sockets. Does the cracking stop? If not, try turning off every single thing in the house apart from the Supernait. Does the crackling stop?
But very specifically, have you tried totally disconnecting the PowerLine adaptors, turning them off and everything? Have you tried borrowing your dealer’s demo SN3?
