I did a routine (?) update of the QNAP HS251+ software yesterday. All seemed to go well, but now I can’t find my Asset server in the Naim app. I’ve rebooted the NAS, stopped and re-started Asset but nothing. Anyone any ideas what’s up? What can I check or try?
Not familiar with naim app but how is asset defined to it… static ip address? Did the nas get assigned the same address following its reboot? Do you use address reservation on your router to prevent it picking up a new one or rely on dhcp and auto discovery?
Hi @GavinB, I suggest you ask the question on the dBpoweramp / Asset forum. The same or similar question about QNAP software updates has been raised before. I’m not familiar enough with QNAP myself but I recall the problem is with QNAP & not in stuff like IP addresses
do you have another control app available, can that find asset ok?
if the other control app find asset, can you delete asset in the naim app and redrive the discovery process?
Apologies for the vague nature, this is just general trouble shooting, as mentioned i know neither asset nor the naim app so if someone else has more detailed knowledge, follow their guidance
Although I only did a check disk following unexpected power cut during last week but all ok after power cut just acted today on Asset warning to run disc check and that’s when server disappeared from app.
I can see the QNAP 251+ on my PC and play from there but no server on the app.
Powered down router, NDS and QNAP but still nothing on app.
@AndyP I’ve re-booted all three - router, NAS and ND but no success. Did you do it in any particular order? What about a switch? Would you suggest doing that too?
I do have a switch but didn’t think about that - worth a try.
Can you see your QNAP music files in windows explorer - firing up a track from there gave me confidence that the QNAP was OK with over 14,000 albums residing on it it’s very precious (backed up of course).
No success last night after the carefully orchestrated re-boot sequence, but…
I tried my iPhone this morning and all was good. Still nothing on the iPad but a re-boot of that has now worked. Sounds like I should have just tried that last night!
