Hi,
does anyone know if the bulb inside the on/off switch of my 1982 NAP 160 is 48 or 60V? Thanks very much.
Max
@NeilS will probably know this.
Likely 48V with an inline resistor.
Neil.
Thanks,
Max
In 1982 I bought a NAP250 ( extruded aluminum case) which uses these wedge T5.5 48v bulbs.
I used to go through 1 bulb every 2 years.
In the old forum, we used to suggest that running the amp sounded better without the bulbs.
Anyway , I continue to play my NAP250 with no bulb, particularly as it’s also too bright at night.
Interesting, thanks.
M
