“Whoosh parrot”
as they say on some forums.
“Whoosh parrot”
It’s a cheap dac. Ifi zen dac 2.
All the equipment was serviced by naim roughly 10 years ago.
I think there are two possible issues here.
The first being a likely need to get the NAP250 serviced.
The second being a source that well out of its depth with the rest of the equipment.
You should look at these two potential issues as a priority.
I had my 250 serviced a few years ago - noticeable improvement. However, @Arvin has said this problem was evident before he got the 250.
Given the system, it seems that we all think an upgrade to the source is likely to be a major change.
On the other hand, I stand by my suggestion to try moving speakers first, not least because it is a lot cheaper than (say) an NDX2.
Good luck!
Maybe the issue is the silver speakers cables the OP use? It would be interesting to know which cables exactly are they.
I read further up that they were replaced by NACA5. Or perhaps the opposite?
Ah yes, you are right. He switched the silver cables for the Naca 5.
Keep up Brown!
