Hello, im really having issues with the installation of the plugin, even with the help of the thread on this forum and also the help file on the github page. i want to try, for now, having Roon setup along with the lms2upnp service on a windows laptop before building something more permenant but i cant for the life of me get lms2upnp installed, its either my ineexperience or not all the files are present in the download, maybe both.
my issue is that while i have got as far as being able (i think) to actually launching the windows version of the plugin file it comes up with an error that there isnt a config file present. the terminoligy of “launching in console” is also a bit new to me.
The explanation of launching it from a console i took to mean that i need to launch it from cmd with the “-i config.xml” tag on the end of the specific binary file, i.e. “squeeze2upnp-x86-static -i config.xml” however there isnt a config.xml file anwhere in the files downloaded and it gives me an appropriate error in command prompt.
I may just be an inexperienced idiot but does anyone know of anywhere that there is an actual idiots guide to installing this? literally a “download the files, extract to a directory, open cmd, type exactly this…” kind of thing? id really like to experiment with the upnp option into my 272 and see if Qobuz and Roon are worth investing in while i can get a free trial.
Thanks in advance
