CDI
1
I would apppreciate assistance with this.
I have inherited a large classical CD collection and rather than just ripping it all I want to play some CD’s first.
Unitiserve / Naim NDS (display gone) 252 SC 555PS, 250.2
I cant locate the Unitiserve remote.
Bought the Coax cable (Mark Grant BNC to BNC) and connected to Unitiserve out to NDS in.
Can’t get any further!
Is this a lost cause with no NDS display or U/S remote?
Can use an old CD radio cassette but thats a bit of a compromise
You need to use Nserve app. You will play the ripped cd, not the cd really.
CDI
3
But I dont want to rip them all - can’t I just play a CD and if I like it - change to rip mode?
Well you can’t on the UnitiCore, so I doubt you can on the Serve?
The remote was an optional extra on the Unitiserve (standard on the HDX) but the N-Serve app on iOS works as a remote and can be used to play CDs.
Short answer : Yes you can.
I still have my UnitiServe SSD purchased approximately 15 years ago.
Naim app: settings and rip mode. Enable to rip, disable to play (if memory serves me correct,I stream mostly these days).
The ability to play and not have to rip is the reason I never moved to a core.
KR
