Just got my XS2 back from Naim for a repair and trying to setup.
I have it and my NAP200 connected to a HiCap.
Source is BlueSound connected to Aux1.
The front input selection buttons don’t light up when selected and I get no output.
Any ideas?
What happens if you take the Hicap and 200 out of the equation and just use the XS2 on its own (fit the bar shaped link plug) ?
Make sure the AV bypass switch is set to off
Do you still have the xs2 powered from the mains? Maybe a basic question but easily overlooked.
Aha! The power cable to the HiCap wasn’t well connected. Duh!
Working great now! Thanks for the response!
