Hi res files best playback muso 2
Hi , I have some Hi res files purchased from Qobuz and want to ask if anyone knows the best playback method using Muso 2. By best I mean the playback method that will be most likely to permit these files to sound as they should ie Hi res and better than CD quality.
I favour keeping it simple if possible, so is as good a way as any (or perhaps even the best way) simply to put them on a USB stick , insert in the Muso’s USB port and use the Naim app to select/ control? Obviously the Naim app isnt very pretty but I don’t care too much about that. If possible , I prefer to avoid using an external DAC with an output device such as a Windows PC.
Hi and welcome to the forum.
Afraid I’m a bit of a luddite on this stuff, I have a few hires tracks on my NAS and they sound great through my Muso QB2 but I’m sure someone will be along to help you further.
Lindsay
Assuming you don’t have a NAS music server that will work fine.
Thanak for your reply So a NAS server would produce better results? If so , how/why?
It may not necessarily be better and you may prefer USB but it’s hugely better to navigate if you have lots of digital music. At a cost though.
When you have many, many files, finding the track or album you want to play can be problematic. That’s when storing the files on a Network Attached Storage device (NAS) is useful. But good ones aren’t cheap, at least by comparison with the cost of a Muso and you need to purchase and install server software on it. There can be quite a steep learning curve, too.
I’d use the USB option to start with. If your music files get a bit out of hand, that’s when I’d start to explore the NAS option.
Roger
Thanks for responding. Yes, I am trying to avoid outlay on additional hardware - at this stage, anyway.
Muso2 here which prompts the observation that, as good as the all in one box is, it won’t deliver significant benefits from attempting to play hi-res files versus cd quality. Any spare funds would perhaps be better directed towards s/h Atom or Nova+ speakers. When funds allow, that will be the biggest sound improvement. Look carefully, even with dealers, very good used bargain, including speakers can be found if patient.
