Hiby R6 III 2025 best connection
What is the best connection for a Hiby R6 III 2025 between the 3.5mm and the USB-C connection?
Thank you
What do you want to connect it to?
Focal Bathys MG
In which case, you have the choice of using the hiby dac or the focal dac.
I would imagine starting with the focal usb dac might prove to be the best option, and use the hiby as a transport only.
