I have just today been trying a Hicap DR on the 62/140 combo, wanting the Olive to go elsewhere. The DR adds a level of what I can only describe as a ‘muddyness’ to the sound. Most surprising. I checked the connections and even tried different connection cables. No improvement. Putting the Olive back in and the clarity has improved. The DR is good as I have been using it with a xs2 where it improves the sq noticeably.
Any reason why this interaction with the older nac should occur?
Yes that’s a decent source. Just goes to show that sometimes, technically better may not be sonically better, particularly with the older kit that was designed with the LM 317 reg based PSUs.
Is it possible that you are now using different sockets on the back of the HCDR compared to its previous use, and that one of those connections has a fault?
OK guys. Thanks for the inputs. I’m not unfamiliar with the connections and having now checked. The hcdr and my olive hc have the same connection topology. No errors in connection.
If the HCDR works well with XS2 but not 62/140, it does sound like a fault. If you are using exactly the same sockets and cables with 62/140 as you were using with XS2, I am stumped - sorry.
@Richard.Dane may be able to help - otherwise the boxes need looking at by Naim or equivalent.
I tried nac 62 and my nac 72 with Hicap Olive, Hicap DR, Supercap Olive, Supercap DR. The Upgrade stays in that order, I still have SC DR.
Facing the olive; when its break-in is ok with DR the result is more “clean” and precise when listening, the bass is firmer and more robust.
Maybe check, see if a snaic influences the result ?
