Hicap or no Hicap?
If a Supernait 3 is used only as a preamp, is there any advantage having a Hicap DR connected as well?
Yes - a HC only powers the preamp section.
It replaces the single rail internal supply (divided into 2 for left and right channels in the upgrade link) with an independant 2 rail 24vDC
Ok, thanks, that should be a better choice.
