Hicap service cost
Does anyone know where I can find the service costs for different bits of kit?
I’ve been wandering around Naim website and can’t find any
Nelly’s Dad
Pricing may have moved on from this 2024 list, but it’ll give you an idea…
https://cdn.mydialoginsight.com/T/OFSYS/H/C1686/169/s0E6E5/2024-service-banding-gbp.pdf?utm_source=dialoginsight&utm_medium=email&utm_campaign=Naim_Service_Band_Pricing_08_24
I’d expect a HiCap to fall in analogue 1 category. Probably worth getting an upgrade to DR spec if appropriate since the upgrade cost wont add hugely to the service itself
Also try Class A in Sheffield. Cheaper than direct to Naim but is official supplier.
I dont think DR “upgrades” are done any more
Martin
Give your local Naim dealer a call and they can get an estimate for you.
£219 plus postage both ways for a HiCap service with ClassA
Perhaps a stupid question but what’s the difference between service end repair (regarding this matter :upside_down_face: )
You put something in for regular service “ preventative “
Repair something is broken requiring repair. :thinking:
Certain Naim items such as power amplifiers and power supplies in particular have a set service routine where every 8-10 or 12-15 years, depending on the item, it’s recommended to have the item serviced by Naim where components such as reservoir capacitors are replaced, bias re-set etc…
Repair is where there’s a fault that requires to be fixed for the item to function properly.
