I got a nap 150, nac112 and a cd5i which I’m lookig to upgrade. But how do you connect a hicap for now? Thanks.
Not an expert here, but what are you aiming to connect the hicap to, the 112 or the cd5i ?
I had a 150/112 with a flatcap 2. I assume the hicap wpuld connect the same. Look online for the 112 manual. It shows that connection.
Cd5i can’t be externally powered unfortunately.
Manuals here.
