"Hidef" radio.
In the NAIM app’s “Hidef” radio choice list, which one or more do you listen to, would recommend and why?
I am using:
  • Hi On Line Radio: Eclectic (listen regularly)
  • JB Radio 2: Alternative and Rock mostly (once in a while)
  • PureClassix: Classics (once in a while)
  • Radio Paradise - Main Mix (listen regularly)
Does anyone have any recommendations for HD Jazz stations?
ALR
Jazz Groove
Smooth Jazz
Jazz 24
Groove Salad
Radio Paradise (mellow mix mostly)
JB Radio
NPO Soul & Jazz HD (Netherlands)
Unfortunately this station is going to be ended somewhere in 2027 due to budget cuts.
That’s too bad, let’s enjoy it while it’s still there in 2026.
2XS and Paradise Rock mix at the moment.
Avoid them like the plague :wink:
You would likely say the same about my likes, too.
Look at XJAZZ stations. You can find them under International / Europe / Germany.
Sometimes in my car Haarlem Shuffle 105 HD (Netherlands)
