Interesting questions as somebody else said.
First of all… dream or obsession? That might be down to the single person and his character. Personally I consider it a dream mixed with a bit of obsession for (relative) perfection. That obsession, if healthy, leads you to optimize your setup to your best possibilities. On the other hand it can make you loose lots of money if you can’t tame it.
So far I’ve been keen on trying as many systems as I could, that helped massively to understand what I wanted and looked for. And it’s not necessarily related to how much you spend. Surely sound is potentially better on more expensive systems, but there’s a limit to this concept as many of us know. I’ve changed and upgraded gear on my system but I’ve done it slowly, properly thinking about it and only if it made sense in order to reach a certain type of sound I wanted.
Will I ever get to perfection? I’m not sure because perfection does not exist. Can I improve my actual system? Of course I can, but by which margin in relation to the money I might spend? All in all I think I’m very happy with my whole setup, I will improve it (hopefully wisely) but I’m not rushing into that right now because the basis is very well covered according to my preferences.
And about the other questions…
- Did you have a sound in your head that would be the goal and did you reach it? Yes I had the sound in my mind and I think I reached most of it.
- Did you hear the perfect system then try to recreate the sound in your own home or was it just what you had hoped it would sound like in your head? Wait… does a perfect system exist?!? I’ve heard some very good ones for sure and those were my reference points along my journey.
- Do you play the same test tracks over and over or do you just play music? I change music according to my mood and the Hi-Fi system surely shaped my taste. Test tracks have always changed over time but I always pick music that I hope I know very well and have already tried on other systems too.
- Are you a perfectionist? I might be, but perfection is a relative concept and it’s just for you to set that limit.
- Is this insane hobby a trap? It’s a great hobby, it taught me a lot too. It’s only a trap if you let yourself fall into the rabbit hole, otherwise there’s absolutely nothing wrong about it. And many other hobbies can be traps too, let’s not forget it. The problem isn’t the hobby but your attitude.
