Hiline RCA to RCA
Hi just wondering whether anybody’s has experience with an RCA to RCA hi-line, do they have the hi-line effect without the rings? Sound as good as the air plug setup?
Cheers in advance
I have one, and it’s a good cable. It has WBT plugs on both ends but of course it doesn’t have the delicate anti microphonic bits like the DIN version. Hard to say how it compares with the DIN version as it wouldn’t be used to connect the same equipment.
I have one. It’s not as good as the DIN version but obviously it’s not meant to be as it’s designed for kit with RCA phonos. It’s at its best if you have the reciprocating WBT next gen sockets in the kit you use it with.
