Hiresaudio - streaming on hifi
I am on a free trial of the Berlin company HIRESAUDIO. COM. How do I get it to play through my ND555. It’s useless if I can only play stuff on my desktop
Try using an optic cable to your ND555?
Too far away
If you can’t use a direct cable connection, the wireless options are Airplay or Chromecast. Not the best options for sound quality but they should work if the app supports them on your computer.
If your ND555 and computer are on wired Ethernet, this would still be a wired network connection.
As far as I can see, Naim streamers are not natively supported (Audiosystems | HIGHRESAUDIO). The only options seem to be software solutions like Audirvana or directly connecting a computer and using their desktop app. Airplay and Vhromecast might work as well but will probably not take full advantage of their high-res streams.
It looks like HQPlayer is supported, so one solution path to try would be HQPlayer via Roon to the ND555
Audirvana or Roon. Upnp to ND555
I bought a Hi Res album from HighResAudio if that is who you mean?
It was a recording made from a poor vinyl album. You could hear the snap crackle and pop.
On complaining I was told but yes it was from a quality recording from a top rate German studio.
