Please, excuse me if this text looks like the sacrilege and the departure from the canons
Some weeks ago I was requesting help on this forum. Since then I made a preorder of nd5xs2 and waiting for confirmation. Unfortunately, the dealer told me that there are heavy odds against me - Brexit(VAT, customs, certification), pandemia, supplies, margins, hell knows what, etc, hell knows what once again.
So, folks, would you mind sharing your non-Naim streamer(renderer) which you connect to the Naim amplifier I need to know how to build the reserve plan. I’ve spent a lot of days searching through this forum but it is an exhausting activity, to collect the statistic.
I’d start from myself - Yamaha WXAD-10. It is good, but not excellent and lacks the digital output. Good bass, good mids, good highs, lots of details, but I always feel that the sound is a bit dull and I’m missing something.
Indeed Innuos looks to be a good choice if you want a separate streamer/DAC ( which I have and think it’s the best option in a fast changing world, not to have DAC and streamer new the one box.)
(The Aries G1 would be an Auralic equivalent)
From reading here their customer support sounds excellent too.
I use a 2009 iMac for music storage & use optical out to an old Cambridge dac. Cost zero as all things I had lying about house in loft, awaiting dump run. Now in use most weekends.
In typical forum fashion alternatives are chord that does not solve anything in terms of being brexitted like Naim. However it does not seem that the Naim dealers in Europe has suffered other than all others with even longer supply times than what is normal.
Claus
If you really want the ND5XS2, I would order it and in the meantime tide yourself over with whatever the dealer can lend you, or e.g. get a used Bluesound Node 2i and sell it on when the Naim kit arrives
Any alternative is an alternative - and whilst it is true that the fundamental factors related to Brexit changes will affect all goods crossing the same border(s) in the same direction(s), different manufacturers may have different supply capacities and capabilities that may make a significant difference to availability and lead time. The same is true of the effect of other current supply chain influences such as pandemia referenced by the OP - who simply asked for people to share what alternatives they use.
In my case a 2012 Mac Mini running Audirvana (streaming my own collection stored on the MM, though it can be used for Tidai & Quobuz etc if desired), into Chord Dave DAC. No preamp because unnecessary additional electronics given that I don’t have an analogue source needing one. Prior to Dave I used a Chord Hugo, with a Gustard U12 isolator-converter between MM and it to remove the RF to which Hugo was susceptible but Dave not. In the future I anticipate possibly changing the MM to something like Innuos or Melco, though a variety of other options make it an uncertain choice in advance of that time coming.
I’m afraid the difference in SQ between wxad and node 2i is negligible as they are built on almost the very same DAC chip.
What I’ve found during my research that a lot of people on this forum use wxad. As I said it is good and I need significant uplift.
Or get a used wxad. I did say “for example” Main point was that if you already decided for the nd5xs2 because it is what you want, just order it and it will arrive at some point. Neither the wxad nor the 2i or other alternatives will kill you in the meantime
