Hi
I am going to us a Raspberry Pi with Home Assistant software to set up home automation.
As part of this I want to automate the Mu-So turning on in the morning and when I arrive home, even better that the volume and radio channel can be set.
Can anyone help with this integration? Is it possible? And if it is how?
You can use the alarm in the firmware but as I remember it you can probably only set one alarm for each day but you can select radio stream and volume for that alarm.
Hi Claus.
Thank you for replying, positive that something can be done.
How do I go about doing this?
Hi Claus,
Can you explain further please?
