If you had to point a finger as to which is the weaker link in the two-link chain of the 552/500, it is unquestionably the former.
In the 552/500 pairing, I have swapped out (one at a time) both the 552 for a better preamp and then keeping the 552 in place, swapping out the 500 for a better power amp.
Once you hear what a better preamp is capable of, the shortcomings of the 552 seem quite large and unacceptable. A better preamp makes the 552 sound small, shut-in, two dimensional, smeared and boomy-NONE of which we hear when moving UP to a 552. But are too easy to hear when the 552 is meaningfully bettered. And it does not take a $100,000+ Statement pre to better the 552 either.
Moving from a 500 to a better power amp reveals that the 500 starts to compress even at modest volumes, loses detail at the top, grip and extension at the bottom and to a lesser extent also sounds shut in.
It is somewhat easy to find a power amp in the 500s price range that ticks more boxes in your set of requirements, than it is to find a worthy competitor to the 552 at the price of a 552…
To beat the 552, it takes an additional $10-20k, and sometimes for a meaningful upgrade $30k extra on top of the 552. The one exception is if your tastes are for a ‘tube’ sound…then a moderately priced tube preamp will give you more of what you are looking for than a 552 could.
Back in the early to mid 80s , there were only a few preamps I heard that made the 32.5/Hicap sound bland and boring.
The Audio Research SP10 mk2 at maybe 10x the cost of the 32.5
The Burmester at maybe 3x to cost of the 32.5 (I don’t remember the model, but if was chromed to the maxx, and in the showroom of Eulipion Audio)
And a Spectral DMC-10 at probably 5x the cost of a 32.5.
All of which were virtually unaffordable to all but a few 32.5 owners.
