I’m with nait2 for months and very satisfied with it.
My main source is streaming. (pc > roon > bluesound node3 > nait2)
Someday I wish I could start LP.
How can I start?
My nait2 is late olive type (does not support phono).
I think I should prepare [external phono + turn table]
Am I right? and if it is, what is the best pair?
(I usually listen jazz and classical music and sometimes old pop.)
(My speaker is harbeth P3ESR and celestian SL6SI)
For pre-1990 music, as a general rule of thumb, I recommend you buy near mint from discogs instead of buying modern reissues. Original releases are always more engaging in my experience. Unless of course they are mega bucks then no choice but to buy new. Enjoy!!
If you want brand new, then Rega P3/Exakt + Neo PSU + Fono MM should be somewhere between $1,500 and $2,000 so worth an audition. Personally, I’d save up for a second hand Majik LP12 provided there’s a reputable Linn dealer within range, which could be tricky in many parts of the US.
Ok - I hope you enjoy the experience! Look out for recent jazz reissues - like Blue Note - which are all analogue and sound excellent. In the U.K., there are many second hand classical LPs that are in mint condition and not at all expensive, but I don’t know if the situation is the same in the US.
I don’t really know. For analogue recordings, the master tapes will have aged another 30+ years so perhaps they’re just not getting as much music from them. Plus, sometimes they are cheapskates and instead of going back to the original tapes, they just use a digital copy that was made for CD/streaming.
There is a very similar thread about budget turntables from someone with a similar budget .
He does have some LPs to start with , my advice is for a Technic SL1500 , your Harbeths are ultra revealing , anything too cheap will be shown up ruthlessly
