How difficult is it to change the cloth cover on QB2? Any hidden snagging points ?
Did my wife’s in about 30 seconds.
Pop off the old one from the spike and socket points, snap on the new one.
Couldn’t be easier.
Finger pressure sufficient?
You worry too much. It couldn’t be more simple.
That’s me - nowadays everything is a huge looming problem in waiting
