I have a muso mark 1. Until recently I have used Tidal and there is a Tidal square tile on the naim app. I moved to Qobuz 3 months ago but the Qobuz is not on the naim app, so I have to use the Qobuz app and then Bluetooth it to the muso. Is there a way of getting Qobuz into the naim app?
I don’t think you can unfortunately.
It’s not “native” to the Muso 1 but other users have reported if they have another, newer Naim piece of kit, (Muso 2, Atom etc) they can play Qobuz on the other kit and multi-room it to the Muso 1.
No can do on the Mk1 but as explained if you have a 2nd Gen streamer you can multiroom and it is very good.
Thanks folks. My other stereo is a Linn so no multi room for me. The muso still does Qobuz via the Qobuz app so that’s the way it is.
Have you tried the usual work around like MConnect Lite or BubbleUPnP software? I have a MuSo2 and until the latest firmware I used them to stream HighRes to it; the support both Tidal and Qobuz, if the MuSo can act as a receiver.
I’d give them a try, if on Android MConnect is very simple to test.
