How do I change the setting on the unity star so that a CD is not automatically ripped?
Hi, since I had to ripp a box of 45 CDs, I changed the setting so that a CD was immediately ripped when I inserted it in the unity star. I now have a CD where one track is ripped with 4 seconds instead of 12 minutes. In order to check whether it is a problem on the CD, I would like to play the CD. But I cannot change the setting back - there is no longer a menu or a setting to do that. I have searched everywhere but cannot find it. Can anybody help, please. Thanks a lot in advance
Kind regards
Wolfram
On the app go to settings, then input settings, then CD Player and then choose the action you want, you have a choice of play, rip or prompt.
