I have a very old home cinema surround system that I either bin and replace or I make use of my current Naim system (without surround) SN3, NDX2 and Kanta 2s. My Sony Bravia is a 2017 49" but I have no idea how to connect it to my SN3.
If your TV has a toslink optical output, use that. Get a suitable length cable from amazon or similar. A Topping DAC (unless you have a DAC already) will then provide an analogue signal to your lovely SN3.
Yes, but make sure to set the tv optical output to stereo pcm. It might be capable of sending surround sound formats which won’t be supported by the ndx2, you’ll just get static otherwise.
I connect my Sony Bravia over Toslink to NDX optical input, then NDX analogue to Supernait.
Supernait + NDX is controlled over System Automation with either iPad Naim app or Narcom remote.
SQ is OK, good in most broadcasts, better with DVD/Blueray.
Just watched & listened to Les Mis, far better than TV sound.
Apologies Spleen, I didn’t realise you already had a suitable streamer. Didn’t read your post accurately…Yes, that DAC is ideal as others have suggested.
Hmm, got a big fat nothing. Connected digital optical audio out from tv to Digital 1 on the NDX2 and despite fiddling with settings - silence. I’m just wondering how compatible my tv is with the streamer.
The only settings I had for the optical out and I tried all 3:
Did that, they weren’t seated properly to begin with as there was some static but once in properly static disappeared and then met with absolute silence.
