I use the car app on my phone and do all that sort of thing before evening putting my coat on.
I agree, but you would be surprised, people still do it.
Iâm another advocate for a good dousing with warm water. Heard countless people (including motoring organisations) claiming itâll crack, but never found anyone who could say theyâd experienced it (or even knew anyone who had.
I do know someone who once cracked a plastic headlight cover with hot water, but never a tempered glass windscreen.
Mark
Tend to agree - boiling water no way! Luke warm/tepid water should be ok.
Which is the reason for Not using very hot or boiling water. I donât know at what point it might be an issue, but as long as you can put your hand in the water without scalding I think it unlikely to pose a risk of cracking the glass. For all I know it might be OK hotter, but warm is enough to do the job very effectively so no point taking any risk.
These days and for many years I thing all windscreens are laminated glass, not tempered, though side windows are likely tombe tempered.
I have an early Land Rover Defender and it takes longer to defrost the inside of the windscreen, then it does the outside.
I then have to drive with the driver side window open a bit, as it instantly re-freezes if not.
The joys of old cars.
DGâŚ
I normally use water from the hot tap and have never had a problem with any car. Warming up the windscreen and wipers is also valuable, since the former minimises any problems with freezing fog and the latter means you have a fighting chance of using them productively!
Mark
My water from the hot tap is 60C, I wouldnât use water that hot.
if ive forgotten to cover the screen then a bottle of water from hot tap but i dont let it run hot so the water is the temp of the pipes in the house so say 15 degrees ish - works with no risk of cracking.
Interesting, we turned ours to 40, safer and economic.
(Donât forget if you draw water from a hot water tank, you do need to get your water to 60 degrees every so often to prevent possibilities of legionnaires disease.)
60 works best for us as the shower runs off the combi boiler. Washer and dishwasher are hot fill too.
Hot fill Washer and Dishwasher�
Had the same with a Jeep Grand Cherokee some while back. Didnât have a scraper but one of my passengers used a credit card. Flexible and effective on a curved surface.
A method I used recently, was to fill a plastic sandwich bag with hand hot water, and then to wipe the screen down with it, following up with a rubber squeegee if required. The heat is normally sufficient. (depending on how heavy the frost is !) This stops you getting splashed with the water.
Next time I will try using a rubber hot water bottle instead. (Less messy than having to untie and empty the plastic bag afterwards !)
Yes, cheaper to heat hot water with gas
Ah yes, thanks for the input! I know in scandinavian countries now I think the max is 40 for safety, but I find it interesting your hot washing machine input can be hot. Cheers
Martin
Fill a freezer bag with hot wall then move it up and down the windscreen!
Trying to imagine what this would look Like did you mean hot water by any chance ?
Itâs an Ebac hot and cold fill.
