Does anyone know how to sign out of Qobuz or Tidal on the Naim app so that I can sign into a different Qobuz or Tidal account?
Jim
Also, is there a manual for the ND5XS2 anywhere?
Jim
No there isn’t any manual as such available.
But if you look at the Naim pages on the ND5XS2 though, and go to bottom of the page, you can touch the support bar and that takes you to Naim’s online help.
Best
Thanks David
Go to Input Settings, choose Tidal or Qobuz, there is a Logout option.
Thanks Eoink - it’s easy when you know how.
Jim
You can also just disable the input and it will log out.
