Planning to get a dedicated CD transport. After a lot of advice and my own research, I got stuck on Austrian Pro-Ject which does a nice little thing called Pro-Ject CD Box RS2 T.
Built of solid aluminum and carbon fiber. Has also come out really well in tests and looks like a very small vinyl player.
The plan is therefore for this to be connected to My NDX2. But are curious about how good the DAC module is that sits there? Is it âgood enoughâ for the current CD transport?
To my ears it is an excellent implementation of the Burr Brown chipset, and can be improved even further with a power supply. I have not heard that cd transport, but the NDX2 is unlikely to be a limiting factor.
I did similar when I still had my Naim CD5 XS which has a coaxial digital output. The transport youâve found will likely do just fine, the NDX2 is a wholly capable streamer.
should I swap for a NDX2 in future, what about using the CDX2 as transport only (digitally connected to NDX2 internal DAC) and move the XPSDR from the latter to NDX2? would it be a general improvement for both sources?
I play the optical out from a TV and a coaxial out from a Cambridge Audio 4K Bluray player into my NDX2 and itâs quite excellent. Indeed, a hi-res audio Bluray or regular CD is very nice as well.
Be mindful of the signal earth if you try this and set the streamer to chassis if the CD player is feeding digits to the ND it will no longer be performing this function. I assume you have the ND5 set to floating at the moment.
from Naim Support: âSelect the default position unless the product is connected in a hi-fi system incorporating another earthed source component, or mains âhumâ is audible through the loudspeakersâ.
ok, that is clear. I will check, anyway.
thus, if CD is feeding digits to the NDX2, I should instead set to âdefaultâ, shouldnât I?
There should be only one signal earth in a Naim system. Their CD players provide this and thereâs no choice in this case, the streamers and DAC allow you to select whether they do this or not by a slider switch on the back in case you also use a CD player.
For some reason they changed the label on the latest series of streamers so it now gives a choice involving default and floating rather than chassis and floating but if all you can see when peering behind it is default than you have to refer to the product page to see whether the alternative is chassis or floating it doesnât say in the quick start guide and thereâs no proper manual, just a rather confusing online menu driven alternative hidden under support rather than manuals and downloads but thatâs progress for you.
I checked and found my ND5 XS2 was set to âdefaultâ but I havenât heard any mains âhumâ, so far; and I use a CD player in my system, too (presumably earthedâŚ).
that was indeed what I found on ND5 XS2 support page, as previously mentioned: âSelect the default position unless the product is connected in a hi-fi system incorporating another earthed source component, or mains âhumâ is audible through the loudspeakersâ.
