I think those work on the principle that the higher you get the disk the less it is affected by gravity, improving sound quality…
The silver one is clearly steam powered, to avoid any electrical noise from the motor. Not so sure about the gold one- initially it inspired thoughts of nuclear power, but then I saw the spare gold weights to the right the penny dropped - it is gravity powered, in a way a bit like a grandfather clock, the weights actually falling slowly and driving it, there being a centifugal regulator inside the central silver cylinder. Another clever way of avoiding electrical noise.
I always had a yearning for this amp, if totally impractical: Beautifully understated front panel - just as well as it’s rather hard to hide at something like 75 cm deep as well as its 30-something cm height. It doubles as central heating for the home, given its 1.5kw or so continuous electricity consumption regardless of sound level (350W RMS output in class A). And at maybe 100kg, wherever you have the fork lift put it, it stays!
Musical Fidelity SA 470
And although irrelevant to this thread, it was said to sound absolutely wonderful!
Not a contest (L) I started this thread to see (possibly unknown) well designed and beautiful equipment. I hadn’t thought of the braun atelier, but glad to see it, but almost everything by Dieter Rams qualifies. I’m really enjoying this whole thread! What I expected to see however was a mix of pieces that may even come from different times. The best looking tuner, the best looking pre-amp,best looking amp…etc. I “simplified” my own list by using a receiver…on any given day, I could alternate between the the cold clean lines of the yamaha - with a gazillion buttons and switches and the warm blue lights of tandberg receivers . To me, these two well known receiver lines qualify of the ones I know… would like to see others too.
But the muso and Qb (and presumably the new Unitis too) have a “cleaning” setting in the app which means you can clean the dust out of the volume control recess without turn8ng the thing off or blowing any speaker cones.
Best
I saw a Naim Statement today in real life for the first time. Looks very cool in person, especially the wavy cooling fins down the side. Actually I think it stars in the movie Interstellar ? TARS = STATEMENT ?
A ‘stack’ of Naim separates CB/Olive/Classic Black has always looks hugely attractive to me in a purposeful way. I can’t think of anyone else (but correct me if I am wrong) other than pre 1990 Studer Revox that can make a stack look great. Maybe it’s the promise of Swiss craftsmanship similar to the appeal of Swiss watches?
