All fair points, and the case against cable excess (and silly claims) looks clear.
On the other hand, if you had (say) £30K speakers, would you still use the QED79 you had when you were 18, or would you think something better might let you ‘hear a difference’ and so try it for yourself?
A year ago, all my cables were standard ‘out of the box’, as they had been over the last 30+ years. During that time, my system’s ‘new for old’ value has gone up by some factor between 5 and 10 - mainly showing how broke I was in the 80s and 90s. The box count has also gone from 3 to 11, with the obvious effect on the knitting behind the rack.
I joined the forum fairly recently because I wanted input and was thinking of changing several things in my hi-fi. Since then: -
LP - still LP12, Kore, Krystal, Ekos, Superline. Now L4 (not L1), Karousel and SRM baseboard and platform.
CD - still CDS II and will be so until it dies.
Streaming - still NDX2/ XPSDR.
Preamp - still 52 & olive (well, more brown) Supercap.
Power amp - changed this week from 250 (used for 30 years, serviced twice) to 300DR.
Speakers - still B&W 804 D3 with 18M TQB2 cables. I needed longer runs so had to replace the A5 anyway, and this bent round doors better.
I have also tried WH Morgana cables & Isoacoustics Gaia IIs, and had a radial mains supply added, as my existing mains and my bouncy floor were suspected weak areas. And I tried some rubbery feet from HRS under various Naim boxes, as well as lots of more DIY support experimentation.
Literally all of the above changes were I think supported by most who commented here, though every one had naysayers too. Somewhat to my annoyance, conventional wisdom or the consensus view has yet to be wrong - I’d be delighted to say ‘You are all mad! This £4.50 device from Argos does exactly the same, you mugs’ or words to that general effect, but it wouldn’t be true.
To my ears, and those of people who have helped out with ‘as blind as we can make it’ tests, every one of these changes ‘worked’ for SQ. On the same basis, the best VFM in that list was getting an electrician to add the radial mains, rather ahead of the L4/ Karousel combo.
Worst VFM is probably the 300DR, but that reflects that I have not sold the 250 it replaced yet. Alternatively, it might well be the change in speaker cable - though I didn’t do that for SQ.
Fortunately, the 300R’s price means that my cable % (on a new-for-old basis) has fallen to a bit over 3% for 2 speaker cables and nearly 3% for the other 9.
I realise that a 6% total will still offend some here, irrespective of how it sounds, but hope the opportunity to sneer makes someone’s day. On the other hand, I still insist on listening to music with my unreliable/ subjective ears instead of looking at a nice objective FR chart, so I am probably irredeemable.
Finally, I thought again about the understandable view that upgrading cables must be meaningless because we don’t upgrade the cables inside the speakers (notwithstanding different lengths).
By this argument, surely it makes no sense for me to ‘upgrade’ my mains supply from meter to hi-fi socket without also changing the cables (Hydra in my case) taking power to the boxes and also getting the street rewired? Why has no-one called any of us who have done the same ridiculous for getting the radial or suggested that ‘squandering’ money in this way was a sign of ‘sheer madness’?
