So, I was all set on which speakers to buy with a 282 / HCDR / 250DR system……but then the 250DR changed into a 300DR so I had a rethink on speakers and knew where I was going…..until my 282 / HCDR changed into a 252 / SCDR……and now I’m a bit stuck!
My speaker budget has been affected and now I’m looking at £10k to £20k……if I go to £20k, then my planned Vertere Calon purchase is cancelled / indefinitely delayed. Speakers must be new and I’m open to standmounts or floorstanders
So, back to title of this post…..what should I do? Any thoughts?
Enviable system, and enviable position to be in. Given your budget for speakers, you have plenty of options. I think conventional wisdom would dictate a home audition.
My system is similar to yours, and it works quite well with Allae’s.
Get the Kudo’s, live with them and enjoy them. You can always spend more money later.
Some may say my Allae’s are the weak link in my system, and I’m there are better speakers, there always are. But they sound great, so I see no need to chase “better”.
Yes - I wish I had that kind of money to spend on hi-fi!
Seriously though, by all means take note of suggestions, but speakers are such a very personal thing and with that kind of money to spend you have a great choice. So think about the kind of sound you want, read around reviews on-line, and above all book some demo sessions and have a listen. Also try at home if at all possible, and if spending that amount,then it really should be. Don’t assume though that more expensive will necessarily be better for you. You may find that a £12k pair suit you better than an £18k pair. In general larger floor standers will give you a sheer sense of reality, of actually being there, that stand mounts can’t. But on the other hand some smaller stand mounts can do some things that larger floor standers can struggle to match.
So you have some work to do, and lots of thinking. But it’s a nice postion to be in. Take your time and don’t rush into anything. Best of luck.
PS:
Really, don’t make a choice based on cost like this. It’s a mistake.
All the dealers I’ve ever spoken to have counselled that the speakers are the last update in the chain. When I was considering the 600s, I could easily have lived with the Keilidhs to their or my grave, but OMO (Odin) the difference of upgrading to what would now be a circa £18000 pair of speakers; everything changed!
Very different sound from Kudos, but truly excellent speakers. I’d find it easy to live with them.
When shopping for new speakers at the time I heard them, I went with 606s instead as once you go active then there is a significant improvement, but I still ponder if I shd get Maxima Amators for another system just given how lovely they are.
With your amp you can go all the way to something like Kudos 808 but it’s really down to what your room will accommodate? Amongst your options are Kudos, Neat, Dynaudio, Spendor amongst others. If home demonstrations are difficult Kudos 505/606 are not room fussy but speakers really are a very personal choice because they really do dictate the tonal nature of your system.
I’ve gone from being set on 808’s to spending more elsewhere on my system and having a lower speaker budget. I was completely sold on the 808’s but that’s no longer an option. Just not sure if upgrading to the 252 and 300 is waste if I pair them with a ‘lower’ level pair of speakers
Whatever, you have to hear to know if they suit you, every speaker’s sound sigbature being different. Personally I wouldn’t restrict to new, but allow at least ex-dem and young secondhand (expect 40years+ without problems from speakers). That would increase your new value up t maybe £30k or more. And I would spend as much as I could afford as long as amp is capable of controlling, as the speakers are the part of a system most responsible for the overallsound character, and if you want full range music good speakers are inevitably expensive as low bass is the part that is most difficult to do well.
With a decent budget like that I’d suggest PMC MB2 - the best speakers I’ve ever heard. Fact 12 might be worth hearing if you have a smaller room I’d also want to hear Kerr Acoustics K100. However with £20k to spend plus a 300 I’d also want to assess a radically different approach, and would want to hear ATC SCM150ASL - not over budget if you sell the 300 - or ATC SCM40A plus a pair of the best recommended REL subs (depends on room size - and I note you haven’t indicated room dimensions, which can be significant to choice).
You’ve said the Titan 505s sound fantastic and tick all your boxes. I’d make them the benchmark, not assume you should spend more because the electronics have changed. Home-demo them against a more expensive alternative and ask what the extra money actually buys you in your room. If you can’t identify a worthwhile improvement, there’s no need to spend another £10k just to make the system look balanced on paper.
