My Atom was doing fine and the last two days has begun acting up again. Again the volume adjustments no longer show and also my Mu-so Qb no longer shows. Yesterday the same happened, I unplugged and waited, no better. Then I did a hard re-set and that resolved the problem. Now today again same thing. So I guess I again do a hard re-set. Is this classified as the screen freeze and should I check out the beta fix?
Yes. A hard re-set again resolved the issue. Now again my Qb shows on multi-room and the volume levels show as I change. It’s a pain because you lose your pre-sets each time.
My HDMI input is completely useless after the last update. It works sometimes but doesn’t allow volume changing from the tv remote. I finally gave in and went out and got a long optical cable for the tv so I can actually get some stability back. I’m done with messing around with it. It worked flawless for a year of ownership then i loose functionality like this… I absolutely love this product but this has really tested my patience.
I completely understand why my wife would think it is faulty and needs sending back… makes me look like a complete fool telling her it Is ok and will be fixed in the next update.
I feel ya…
