To power the NAC32 with the SNAPS you should connect a SNAIC4 to Socket 2 on the SNAPS and then to OUTPUT 2 on the NAC32. However you’ll need a power amp to drive the speakers. Which power amp are you using?
If you connect the snaps to the 32 as Richard says, you can then get a signal from the 32’s tape out into the HK. Bear in mind though that you will still be using the HK as preamp, with the Naim working solely as a phono stage. The 32 is a top notch preamp and way better than the HK. If you added a matching Naim power amp, such as a 110 or 140 you’d have a fantastic vintage amp. The snaps is rather elderly and is almost certainly in need of a service. I wonder if that makes sense.
