How to connect an external DAC to my NDX2
I’m sure this has been discussed before so sorry for the redundant question.
I don’t understand how to connect a Qutest to the digital output from the NDX2. I see only 1 BNC output. Does that one output handle both L&R channels? What cable is recommended for this input to the Qutest?
Thanks for any help on this simple question.
See above thread. The Qutest has two BNC inputs, “1” and “2”, not L and R.
Perfect. Thanks. Any settings on the NDX2 I need to concern myself with?
Make sure you have the output set for Digital BNC.
Native sounds better than PCM with my HugoTT
Thanks for your insight.
