Hi
Can anyone help please. I recently upgraded the firmware on my Atom to 3.5.1 but it has adversely affected the sound quality. How can i revert to the previous version please ?
Hi
You will have to discuss with Naim support.
They won’t want you to downgrade and will probably suggest you do a factory reset of the Atom.
Best
Several people on forum have reported that a factory reset clears any adverse effect in SQ after firmware upgrade
I would definitely do a reset first. If you still feel that sound quality has been adversely affected then contact Naim tech support.
Thanks - will do
