Bemused as to how to do this ?
Entered this question into the search engine … nothing relevant.
All I can seem to find is the option to add a profile pic.
Where might I be going wrong ?
Am I losing my marbles ?
SJ.
Preferences, account, profile.
Click on your name on the top right hand corner and select Preferences
Then select profile on left hand side
Edit your profile. Click your username/picture, preferences, then profile preferences, should do it. System details down the bottom. Assuming you’re using the mobile app?
Am using Windows 10.
Pretty sure that was pretty much the thing I tried first … and came back to again, without joy.
Hence the frustration.
Will try again.
Cheers.
Ahh … got it.
Wasn’t scrolling down, it seems.
Thanks for the help.
SJ.
FYI we can see your email address in the screenshot.
Ah, thanks, appreciated!
