Hello everybody.
I am a lover of the Naim brand from Italy.
My system is:
252 + SUPERCAP DR
NDS + PS555DR
300 DR
HiLine, NAC A5
PROAC D48R + ISOACOUSTICS GAIA II
VPI PRIME 21 TURNTABLE + ISOACOUSTICS DELOS
Professional acoustic treatment of walls and ceiling
I have a large salon.
The Proac D48Rs are well spaced from the side and back walls and I have installed quality Bass Traps in the corners.
All the electronics are placed in quality racks to try to eliminate the noise that comes from the acoustic waves of the music.
Each electronics has its own dedicated Naim Powerline cable, I have a dedicated power line for the audio system, I have star strips and each electronics are in phase.
I would like your opinion on an upgrade for my loudspeakers Proac D48R.
What other loudspeakers could be better than the Proac D48R for my system?
Could Focal Sopra 2 be better than Proac D48R?
What is my problem?
The problem is that the desire to improve seems to never end.
In particular, the Proac D48R seem to find it difficult to reproduce beyond a certain volume.
I can turn the volume up to max just before the middle of the 252âs potentiometer.
After the music is played with too much emphasis in my opinion the mids and the bass start to be excessive, almost having the impression that the speakers may break and that they do not have the ability to play the music properly.
Even the treble at about half of the potentiometer is excessive in my opinion and the reproduction of music becomes tiring as well as the voices.
It is strange because the Proac D48R have a recommended maximum of 250W while the Naim 300 DR is declared as 90W.
But at lower volumes the Proacs give exquisite music, in my system with a very high soundstage as well as a âcloudâ of beautiful sounds and details.
In short, the general impression is that the Proac D48Rs beyond a certain volume (generally just before halfway through the Naim 252 volume potentiometer) are unable to reproduce the music correctly in my system.
The D48Rs have two 16.5 cm mid woofers and a ribbon tweeter in my case (D48 ribbon in fact).
Are the Proac D48R the weak side of the system?
What other alternative speakers to the Proac D48R could make me make a worthy leap in quality without spending too much money?
Thanks for your valuable opinions and comments.
