Ive just acquired second hand system but cannot see how to power down my headline and NAPSC as they don’t have switches. Any ideas?
Pull out the mains plug that supplies the NAPSC - there is no switch.
Haha not a technical solution then! thanks.
Alternatively…don’t! There’s a reason why they don’t have switches.
Well that’s another conservation (plenty of threads about that on the forum). The OP asked how to turn them off hence the answer…
@ChrisSU can you explain why we should let the NAPSC on? I have it and HICAP power for my NAC202, if don’t unplug, NAC202 light on the buttons keep flashing.
