Apart from the CD you haven’t clarified what is connected if anything to the other cables. Nor have you clarified whether the CD player is a Naim or other make. If the cables hun with nothing connected then it may be that the cables themselves are the problem, not adequately shielded. On the other hand if they are connected to something it could be either a ground loop or a fault with the source, or the cable (disconnect the cable from the source to identify whether it’s the cable). Regarding ground loops, have you tried changing the settings of ground lift switches on whatever items have them?
What source and speakers do you have? 12o’clock is way louder than you could actually play music at with a typical modern source component and speakers, at least for most systems, rooms and ears. So maybe it’s nothing to worry about at normal listening levels? Having said that, if I turn my preamp up to 12 o’clock the speakers remain silent, with only a faint hiss if I turn it to max volume, so maybe there is something worth investigating.
Thank you. Sorry for the vagueness, my technical knowledge isn’t great, but here goes…
Inputs into 202 are:
CD5x
Apple airport express (output 2.5mm jack) connected to tuner DIN input for some streaming
tape input unused
av input unused
TV set top box (twin phono output) to DIN aux 1 input
turntable to Naim stageline to aux2 DIN input
Flatcap2 powers 202 and CD5x
original Naim power and SNAIC cables, power cables are bundled into one single power plug (3 pin square)
Naim Allae speakers and NACA cables
Xanthe, thanks for the question, can you explain more on what you mean on the 202 settings?
Chris, completely agree that 12 o’clock is way higher than I’d ever attempt, so perhaps the buzz is a non-issue and I should be getting concerned, but I wonder if it would improve the overall sound if I identified the source of the buzz and removed it.
As a reminder, here’s where the noise is found when 202 volume is up high (with nothing playing):
from the AUX 1 input both channels - stops when cable removed from DIN
from the CD input, remains on left channel when CD switched off, but stops when the cable removed from DIN
