Huming Nap 250dr
The cable between the 272 and 250DR? I use the original. Is it a common statement that changing this one is of big improvement?
No sure what you mean by common statement…
And I wouldn’t speak for others
But I bought a Chord tuned aray from a well known …try it .. don’t like it… return it… emporium, and thought I would do just that… return it after the trial as I thought " no cable can be worth £800+
…well I don’t return it … enough said?
Separation. Bass. Space. Everything to the better i think
I just got a new 250DR and it has a much louder hum than my previous 200. It is the only appliance on a dedicated spur I got put into the house when I got work done.
Anyone got any idea what could be causing it?
For me it was DC. Completely quiet after buying a supra DC blocker. So quiet I started to get annoyed by the buzz in my NAC 272 so I connected the entire hifi kit on the supra
