Nak CR5-e
I’ve disconnected the tape recorder and still get a hum when the mute is off on AUX2.
I’ve tried the Nak connected to different inputs too.
I’m using a 4 pin DIN to RCA on AUX2
Weirdly I only get the humming when both the RCA’s (L&R) are connected. If I remove 1 (doesn’t matter which) the humming stops.
Weird I don’t get a hum when the record mute is activated or when I select a different source on the record section
A DIN4 to RCA doesn’t sound right. Unless you Are you taking signal directly from the Supercap to your Nak? If so, you don’t want to connect from the Nak back into the 252 otherwise you’ll likely get an almighty hum from an earth loop.
You should use a tape I/c (4xRCA phono to DIN5) on a buffered record in/out.
Hi
Sorry - don’t think I was clear.
I’m using a 5pin to RCA set for the Nak. The 4 pin to RCA is from a Superline connected Supercap to 252 AUX2 RCA input. That’s where the issue is.
Make sense ?
